Black Cloud Boob Job Build Thread
AaronB
Longmont, CO
Sweet, a pallet Jack. Those come in handy.
Sweet, sarcasm.
UPDATE
So Monday the surgeon said that if I could still move my finger in both directions (which I can), then the tendons were still attached at least partially, and with time they would heal (hopefully), without surgery. They put me in a smaller splint and told me to let it heal for at least the next week and made a follow up exam for next Monday. They also put me on antibiotics as a precaution, and renewed my pain meds. So needless to say, I promptly drove back to the shop and started working.
Wednesday the transmission arrived. And the Hughes' 4L80E is pretty. The bell housing is actually smaller than a stock 4L80E by almost an inch and a half. Good news for those of us trying to find room for everything.
Even came with the dyno sheet
AaronB
Longmont, CO
You guys wanted some fab? Enjoy!
So while waiting for some crucial parts to arrive, we started working on some of the body. First up was the taillight pockets and tailgate assembly. Knowing that Coby wants the body to stay stock width and that stock tail light pockets are hard to find, we opted to keep the originals. They were pretty hammered, but workable. After they were cleaned up (blasted then primed with weld thru, self etching primer), new mounts were made to hold the stock tailgate mounts. We want as much clearance as possible so we modified the stock brackets and made new mounts using some cage nuts and some angle. We used 2" x 3" x 11 ga square tube are the anchor to hold everything together. We also ran some 1" x 1" x 11ga square inside of the tail light pockets to reinforce them.
Then some brand new panels got hacked apart before more mockup.
Mock up
Knowing Coby wanted an all steel body, we also started work of making steel "door inserts".
The fiberglass ones:
New steel:
AaronB
Longmont, CO
With the trans arrival on Wednesday afternoon, we could finally start on the chassis. Having to work around the fact we still don't have some pretty important pieces to the puzzle, I chose to start with the main frame rails. Trying to accommodate everything while keeping a "stock" or "factory" look, will be challenging.
We started by placing the motor and trans on the fab table and centering them. We then laid out what we could based off the rough sketches and the few dimensions we actually have. To make things easier, I quickly bent a few pieces of tube up to help with the layout. I bent them where the firewall would be and then tacked the other end to the rear cross member/tail light housing. Then we laid out the rest in tape on the table.
Once we had the majority laid out, we could figure out the main rails.
We have accomplished more than this as well the past few days, but the additional photos haven't been uploaded yet. I will try to update more later.
360 4V
I did no cut my hand that deep with my angle grinder. I did however have cigarette butt burns from my chin to my lead fishing weights. I knew I was going to burn sooner or later! Better now than later!
C
coby
Fort Collins, CO
FedEx man brought a long awaited for goodie. I'll take more pics later....but here's a quickie. This is one I've wanted for YEARS.
C
coby
Fort Collins, CO
Oh my. Oh oh oh........ Whoops got carried away there for a sec
I know whatcha mean. I had to clean it down before I took that shot. Here's another.
Now I just need to get the Hogan sheetmetal intake in so we can mock up the motor for clearances. Really wish the BC Broncos stuff would come in....not sure what's up with them right now. Need that desperately to get the front end of the motor all finished out for doing the tubework.
AaronB
Longmont, CO
AMEN! Preach brother preach!
BTW- can't wait to get my grubby hands on that BEAUTIFUL piece-o-art Whipple sent you. God it is pretty.
AaronB
Longmont, CO
Bent up a tube at the "firewall". We bent it to represent both the firewall and the outer most part of the exo. Meaning the front fender will sit just within the hoop. And we also semi mocked up where the front axle will end up. Again, we are fabing on the fly without all the necessary components, so not much is really written in stone. And you may notice things changing as we deal with snags along the way.
With the engine and trans laid out the way we liked, it was time to start on the motor mounts. We elected to use the "heavy duty" mounts he had recently installed, and build to them. Knowing we needed as much clearance as possible because of the 50 degrees of steering and the 42's only left 21" inside of tire to inside of tire at full lock. Yup, I just said 50 degrees of steering (gotta love the Spidertrax knuckle setup), and less than two feet in between the tires at full lock. Sick.
So we started with a flat plate bolted to the mount.
Then bent a few tubes to meet the top of the plates. And with the amount of power that this will have I wanted to tie both mount together.
AaronB
Longmont, CO
With the motor secured in the chassis, we then were able to actually place the front axle. We mocked everything up at full compression in order to help solve our clearance issues. We also made half a 42" tire to show how tight everything is going to be. 50 degrees of steering is nuts. And yes, the oil filter will need to be relocated.
AaronB
Longmont, CO
We have been referring to the time spent in the shop lately as "Arts and Crafts time". We still haven't seen the Atlas 4 speed yet, so we made our own.
Also been working on mocking up the front suspension. Front top truss mock up:
And also made the first set of waterjeted brackets and tabs. Waterjet parts are so nice and clean, with beautiful crisp edges.
http://mostlyharmless.smugmug.com/T...y/i-qbc5nb9/0/XL/2012-03-1512-57-20720-XL.jpg
360 4V
You guys are great!
When I grow up I want to be like you guys!
You are artists and engineers!
