Blast cabinet venting ideas?
Jaybr
Wife got me a Scatblast cabinet for Christmas, I know it’s early but she couldn’t exactly hide it when the freight truck dropped it in the driveway when we where out. The cabinet came with a dedicated vacuum and recommended to vent outside. They make a venting kit but it looks like a standard dryer vent and I’m hesitant to drill a 4 1/4” hole through the brick wall.
I’m sure some of you have blasting cabinets, do you have your vacuum vented out of the garage and what did you use?
We have a couple at work. The old one is roughly 25 years old. It tends to put a light haze of dust in the air when it is running. I know they went and changed out all the seals and try to keep it up to date. It has left the haze for as long as I can remember.
The new one is maybe 5 years old. Don't see the haze in the air. But you see a little around the machine after a long run.
Neither are vented outside. Just some fancy multi-stage filtering setup.
Harbor Freight special I once had (hand me down that I further handed down) was modded to run into a shop vac, I remember the filter didn't get much run time before you started seeing dust lofting out of the seams on the cabinet.
I don't know how good of a one you got. Nor do I know your levels of acceptable shop dirt. But if they state to run a dryer vent outside, I probably would follow that advise. You can probably do a temp version and see how things go before fully committing to drilling that hole.
Jaybr
Jaybr
Thanks,
It seems to be a very well made cabinet and made in USA. Definitely not a Harbor Freight cabinet. When I was younger I didn't pay much attention to stuff like dust, but as I've gotten older I do. The dust itself wouldn't bother me but apparently sand has silica in it that is very bad for your lungs.
McGirr455
I have 2 holes in my home built blast cabnet, one for fresh air and the other is hooked to my shop vac with a drywall bag in it. Worked well for the last 15 years.
ransil
i always had the vac that came with the blaster next to the blaster, noisy but not like i used it all the time.
i used crushed glass for blasting., modified the exhaust tubing using pvc pipe.
FordBronc
Bronco's, yea I have a couple.
Polk County, Missouri
A few buddies say..."I also have the cheap HF cabinet. Wish it was bigger but do the big stuff outside. A few tricks...When assembling, seal all the seams with silicone. Use rivnuts instead of the screws and nuts on the window fasteners, makes changing screen a pleasure. Got tired of wearing out nozzles, so I got a Trinity Tool (Trinco) gun with carbide nozzle and a foot valve. Nozzle good as new after 15 yrs. Mount your vacuum over head if possible and vent to the outside via a clothes type dryer vent. Dust goes up, heavier stuff falls back down. One more trick...On the inside of the plastic window, cover it up with clear packing tape. Lasts 3 times longer than the plastic, tear it off and replace it when cloudy.
"I have the harbor freight free standing cabinet. I have their add-on reclaimer vacuum, the 5 gallon bucket dust separator that is inline with the vacuum, and finally a skat blast media shaker that funnels the media off the sides and into the hopper. I use my cabinet relentlessly with my 80 gallon single stage compressor. The money I've saved by re-doing existing parts in lieu of purchase has paid for this system countless times over. I installed foam tape around the cutout for the door to cut down on spillage when opening the door. I assembled with silicone and as mentioned previous, I used rivnuts which make replacing the glass a snap. I also have a super bright LED light in the cabinet. I wish it were taller however as being bent over for hours makes for a rough night. I have it on a mobile base as I don't have room for a dedicated blast area."
You do not want to be breathing anything that comes out of it. Some folks wear a cheek 2 filter respirator when operating it.
Jaybr
Jaybr
Thanks for the ideas folks, I think I’ll try one of the bucket dust collectors between the cabinet and vacuum first (wearing respirator) and see how it does. If there’s any hint of escaping dust I’ll drill the hole and vent outside.
This is the cabinet, just need to clear the spot and get it moved and setup.
Madgyver
Bronco Madman
My Snap On blast cabinet vents into 2 big bags from 2 exhaust fans. The bags catches the dust. I got it in a trade for Bronco parts. I modified the legs and mounted the cabinet on big 4" casters. Easy to move.
56f100bbw
Tucson / lakeside AZ
I got 2 blast cabinets both on big casters nice for moving around The one in the picture is my small one tall cleaner vacuum cleaner cloth bag the other one I exhaust outside no filter ,big cabinet you could put 2 men in it I always buy used in good shape , need a big air compressor to run it
El Kabong
Driving stuff Henry built
Here's a thread where the guy makes a harbor freight cabinet work well for him. I think he ended up with a Dust Deputy set up on his vacuum side. You might not need all he does, but he goes thru a lot of grief getting it sorted out & shares the steps along the way.
hyghlndr
Hockessin, Delaware
Definitely go the bucket route, it is a great upgrade and will make the vacuum last a lot longer. I never bother with drilling through the wall, for as often as I use it I sent the vacuum outside when using with door part way open.
That is a nice looking blast cabinet. It might actually have some pretty good filters already on it. The good new one at work does.
The HF and other cheap cabinets need a lot of help in the dust collection or just flat out dust extraction/disposal.
Jaybr
Jaybr
Got the wheel kit for it and installed this week. I ordered the high version that raises it 3” as I’m 6’2” and don’t want to have to bend over to use.
Jaybr
Jaybr
Got it all setup and tried it out tonight. The vac setup that came with it seems to work really well, didn’t notice any dust outside the cabinet and the inside stayed really clear. Spent <10 minutes on this, this thing is going to save a lot of time
daddycreswell
Lebanon, TN
Got it all setup and tried it out tonight. The vac setup that came with it seems to work really well, didn’t notice any dust outside the cabinet and the inside stayed really clear. Spent QUOTE]What size compressor are you running on it? Not that I have room for a large blaster, or would be nice.
Sent from my SM-S901U using Tapatalk
Jaybr
Jaybr
5 hp Quincy with 80 gal tank - rated 17.2 cfm at 175 psi
