My blinkers were working, then stopped. Hazards worked intermittent at best. Now both are not working. I’ve searched the forum, but am not finding an answer that helps (and it seems you are lucky if anyone ever reposts with a fix! Haha) Here is what I have going on:
Headlights: work normal
Hi-beams: right side does not illuminate (I need to replace pigtail like I did on left side)
Tail lights: work normal
Brake lights: work normal
Right turn signal: does not work
Left turn signal: does not work
R turn signal + brakes: R side solid taillight only/L side brake light, no front light, no dash indication
L turn signal + brakes: L side solid taillight only/R side brake light, no front light, no dash indication
Hazards: do not work
Hazards + Brake: Front L & R turn signals come on solid, both dash indicators on solid, rear brake lights on solid
Rear lights are LEDs; I believe the fronts are incandescent. I replaced some very old looking 552 flashers with Novita LL552 flashers, no change. I read more about electronic flashers and LEDs, and thought I would need to replace the LL552s. When I went back to AutoZone, their computer said the 552 were electric, and the packaging said works with LEDs. They had no other electric flashers with 2 prongs. However, this website says it is electro mechanical, but still works with LEDs:
https://www.autozone.com/electrical...ovita-turn-signal-flasher/849393_642494_11714
I’m surprised the rear LEDs even worked with the old flashers that I pulled out, but they once did. Not sure if I need to buy some other kind of electronic flasher, or just go to incandescent bulbs, or if my issue is in the steering column? I believe the steering column is a 1977, C4 auto with column shift. Hazard switch is on the right side of column.
On a not very related note, the light for the gear indicator is nearly useless. The bottom of the plastic indicator prisim is black, and seems to cover up anyway for light to illuminate the clear plastic. Was OE that way and I have some crap aftermarket indicator? Or if OE was that way, how is that dim bulb supposed to illuminate the indicators? Gear indicator hood is in place.
Thanks for the help guys! Hope this is as easy as I have wrong flashers or I need old-school bulbs. Please don't say it is a "find the poor ground" issue! haha
