Blueprint Crate Engine:BP306MAXCT Questions
tripleJs15
I'm thinking about going with this setup in my second Bronco and have no clue what front accessory drive setup for Alternator, Power steering, A/C, What starter, headers, stock or EFI tank, harness, auto trans setup would work with it. Should I do any body lift, I currently have a 2.5 suspension lift, 33" tires, Dana 20, I think 3.XX gears, will confirm.
Has anyone used the BluePrint Engines BP306MAXCT before and can provide some advice and/or guidance?
Link: https://www.summitracing.com/parts/mll-bp306maxctf
FYI: Very new to the Bronco world!
Rangerbj
I know my engine is different from yours. I installed a BluePrint engine, part number BP3023CTC in my 1973 and just pulled accessories off my original 302. They fit perfectly. Very easy
T
tripleJs15
Good to know - to confirm that's including powersteering ? Which starter did you use?
Any hood clearance issues or do you have a body lift?
