Blueprint motors Bronco spec 306 cam specs. Does anyone have them?
markw
Does anyone have the cam specs for this motor?
Thanks In advance. Mark
lars
Been here awhile
NorCal flatlands
Which year, Mark? As far as I know they used to source all their cams from Comp Cams, off the shelf grinds. But they have changed over the years. My engine(s) being an example. No idea what they are using now.
.94 OR
Willamette Valley, OR
I happened across the spec sheet for a 390Hp/370Tq motor. I'm guessing the difference is in the cam but I haven't seen those specs.
M
markw
Thanks guys! The engine is about 10 years old. I’m sure the specs you found will work.
M
markw
Hey Lars, I just put a new cam synchronizer with your adapter in the race Bronco. Garry built a beautiful new harness so I can use the Explorer ECU. B awhile before we get it running but is so much nicer than what we had before.
Soylent
California
Just to clarify the spec sheet for my motor above is not for Blueprints “Bronco” motor. They were out of stock for several months so I went with that one. Was about 8+ years ago. The hp/tq curves were a little more “upstairs” from the Bronco edition iirc.
chuckji
SE Michigan
I’ve had my Blueprint 306 Bronco Edition for 7 years. Couldn’t find the spec sheet, but found this in an old email communication I had with a Holley Sniper tuner.
