Body mount/flex?
kaw550
I went to look at a Bronco that was for sale.
When looking at the rear bumper I noticed there was a 2" body lift. Then I noticed the the rest of the mounts only had the stock rubber mount, no lift.
The body looked level. It had fiberglass inserts and soft doors so I really could not check the alignment.
The frame looked solid. Any ideas?
I assume if they were removed, it would flex at the door opening. Do the fiberglass inserts flex at all?
Mherriford
Oregon City, OR
yeah the door opening are'nt all that square on my bronco and it is pretty easy to line up the inserts for me just have to push them into place and screw them down
SaddleUp
Vancouver, WA
Look down the body lines and see if they both look level. If they are not level then chances are the body mounts have been crushed. In this case if they are level then chances are that the rear mounts where it has blocks are crushed.
kaw550
kaw550
I didnt look down the body lines but from the side of the truck it looked good. From the back it had the gap between the tailgate and the bumper.
I did compare the mounts to the next two forward and they looked like they were the same size, but the back mounts had the additional block.
