Body mount pad repair Question
Revelation
The pads on the frame for the body mounts are rusted, not structurly but the holes are enlarged, what is the best fix for this? would fabing plates to sit on top and weld into place work? I know that if I use 1/8" plate it will raise the body 1/8",or should I just find new brackets and replace?
Mikeg23
Greenwood, IN
My frame was rusted to where the hole for the bolt was the size of the bushing.
This was the rear most body mount and I just put a plate in it, actually I used two pieces of angle. I can't remember how thick it was but but it seems to work fine.
PS. If you were scared half to death twice wouldn't you only be 3/4 scared to death. Or would the second time just be considered half again. :)
Mark
Bronco Klutz
NW Indiana
Kinda like this?...
I picked up some huge washers that are the perfect size at the hardware store and welded them on.
I've done this to 10 mounts!
Revelation
Revelation
mark that one in your pics look just like mine, Thanks for the vote of confidence on my solution, glad to see that I do not have to replace them totally
