Body mount replacement, help on locations
zonian
St. Augustine
Hello! I'm getting ready to replace my worn body mounts with tbp's kit. Can anyone help with a diagram of the number and location of the existing mounts? I searched the thread but the two mentioned measurement schematics won't upload.
The simpler the better, I'm a low tech garage monkey! Thx
ENDLIFE
There are eight mounts total. Two in the front directly behind the core support (passenger side is under the battery tray), two located on the on the floor pans about a foot in front of the front seats, two more behind the front seats (under them if the seats are all the way back), and the last two are about an inch just before the tailgate.
Just did mine about a month ago.
Pops68
Bronco Rookie
Bazetta Township
Do one side at a time - all 4 on drivers side and all 4 on passenger side. Did mine several years ago, wasn't too bad......lots of sawzall blades needed/used!!!
Pops
Attac
Hey,
Check your Private messages.
I am sending you my phone number.
If you want to come to my shop we can do it here.
Chuck
half cab
Guru Bronco
dont forget to put duct tape over the holes in the frame when replacing the body mounts behind the seats.
If you do drop one in the frame just stick the air nozzle in the frame and blow it to the front or back .
