GOPSU
Just put new body mounts on my 76. Is there a recommended torque value for these? I've heard lots of stories of overtightening and pulling the bolt through the mount For now, I tightened them at 20 foot lbs.
Jopsu, Ballpark time it took to change your mounts? Any challenges? My mounts look like originals from 1973 and I'm considering changing them. Thanks
Update, I contacted the floor builder and they didn't really know what was going on. The dynacorn floor definitely doesn't have a spacer/bushing between the upper floor platform and the floor support so it crushed. Im still waiting to hear something back about this and will update once I do. Im also considering starting a separate thread for the floor.
So after extensive discussion with dynacorn they told me the same thing that this was part of the mounting kit. My truck has a brand new body mount bushing kit from Toms. So I called them up and the bushing kit doesn’t supply the bushing (steel sleeve) which is meant to be installed inside the welded floor from the during assembly. The front mounting location does have steel sleeves inside however the rear doesn’t. Toms was very helpful with this. Unfortunately, I order the floor from another supplier who told me to just not tighten it down and I will be good to go. Has anyone run a floor without the steel sleeve and could you post a link to the mount kit which has it included?
