Body Restoration
Zeke
Hey Fellas,
I am getting ready to start the body restoration on my 77 Sport.
It's got the typical east coast cancer. It will need floorpans,
front floorpan support, kick panels and inner fender supports.
I am sort of unsure of the sequence of replacing these parts.
I was thinking of the following;
- jack up the sagging body and check all the measurements
and door gaps.
- cut out the floorpans and floorpan support and weld
in the new
- working my way forward replace the kick panels and
then last the inner fender supports
Is this the best way to go ? Please give me ANY suggestions
and ideas you all have ( besides selling !!!).
I am thinking of getting my sheetmetal from Autokrafters
( local ). Any other suggestions of who to get sheetmetal
from ?
Thanks,
Zeke
thegreatjustino
Red Head Grease Monkey
Stockton, CA
from ?
Sorry I can't help you with the order of replacement, but after being thoroughly ripped off by Auto Krafters about three years ago, I would fabricte my own parts before I'd give them my business again.
MI-Bronco
I can't speak to AuotKrafters, but the sequence looks good. If you have that much cancer around the door post, you better check its structure. Replacing the door post might cause it all to be done at once....
IowaMike
Make sure you brace things before cutting out the old. That way your dimensions should stay the same and gaps will be right when finished. I'm starting to get the idea the guys (PO) that did the floorpans on my '68 didn't do this, as I have more gap between door and body on the passenger side than I do on the driver's side.
Shubyjames
Tunkhannock, PA
Zeke,
Your order looks good, very similar to the way I did mine. If you have the ability to do all that then I think it would be safe to assume you have worked with sheet metal before. If that is so, I would suggest making your own parts, and if you did you could use any gauge you want provided you calculate the extra into you measurements. That’s what I did. For the most part everything that you would be making is flat with straight angles—very easy work.
Here is a tread of some of what I did:
http://www.classicbroncos.com/forums/showthread.php?s=&threadid=37386
Just mi2,
Shuby
HotWheels
Twilight Zone
having been doing the same for the last 7 months I would recommend Dennis Carpenter. Forget the tail light panels though..try and save the ones you have or find some off a wrecked one. No one makes good ones.
