body shop question
guidoverduci
NorCal
Been searching for a bronco and keep coming across ones that just need a little body work. My question, assuming a project bronco that needs all four quarter panels replaced and floor pans, but no other body work (I know... slim chance..), what's a rough cost for repair work? I figured 1K + in parts, but what's the labor usually run? Just looking for real rough estimates. Trying to decide if I should go this route! Thanks
broncobsession
I estimate double the parts bill. The fenders are easy but floors and quarters harder. 20 hours at $100/hr is $2k. So with the metal ~$3k total. Would they paint too?
Plus when they open things up and see you need kick panels and one door post and the bottom of the taillight panel replaced it will go up from there ;)
thegreatjustino
Red Head Grease Monkey
Stockton, CA
The real issue is finding a shop that will do that type of work. Most local body shops won't touch classic vehicles, so you need to find a restoration shop which usually costs more. You say all four quarter panels. Are you talking about two uppers and two lowers as the four, or are you talking about the front fenders as two? The front fenders just bolt on and can be taken off and put on with common hand tools.
Quarter panel replacement would run $1,000 per side and maybe a little less for the floors. At least in my experience.
G
guidoverduci
NorCal
Thanks for the info! I was unaware the fronts just bolt on, that helps. What I'm really after is getting the rear fenders flared like the front. I'm trying to decide if I should find an uncut good body, or just something that needs the panels replaced and then have the rear flared.
englewoodcowboy
Lick Creek Restorations
Usually you will find more parts that need repair or replacement as you dig in. I would estimate 2500 in parts (dot forget the shipping is part of my estimate) and 40 to 60 hours of labor if you want it done right. I would say a more realistic number is from 6500 to 8500 to get it to a solid tub. Take a look at my build and you can see on the surface my bronco looked like it only needed floors and inner front fenders.... once the paint was stripped it needed much more than that.
spray1963
Boca Raton,FL
I replaced the floor pans, inner and outer rockers, firewall assembly. windshield support, and front door posts. Parts were about 1500 and labor to get it all put together to have all the door gaps right was $8K. My son and I sandblaster the tub and epoxy primed everything. The final body prep and paint was another $10K. This was a truck that looked OK until we dug into it. We did all of this while also rebuilding the entire drive train. this whole project took 16 months to do working just about every night and weekend.
Here are some pictures of what was done.....
WorkerBee
Northern CA
I started with what was considered a pretty straight/minimal rust Bronco. Once it was opened up there was buried damage with 70's era bodywork. Looks can be deceiving. My point is, start with the best one you can afford.
Let's just say it was expensive to fix it correctly. I found a pro that did side work after being told "we won't touch it" by a few body shops.
Ended up with a way better job than I was expecting. It's actually getting delivered this afternoon!
Where in Norcal are you? I can always pass my contact along.
Great looking project conclusion there spray! For such a straight-looking EB originally, there's not much you didn't have to tweak or replace, is there?%)
ep67bro
Bronco Junky
Easton, MD
A lot is what it cost!!!!
Body work and paint work gets expensive really fast. And if you think it will be $4,000 in the end it will be $8,000. Rust never sleeps! And if you get paint work done the price can vary depending on color and paint type. Call around find a few shops that are even willing to work on the truck and then get some estimates, get some references too!
sykanr0ng
To throw out an alternative; is there a community college near you?
Many of them have auto body classes and will encourage students to bring their own vehicles to work on.
That way you could do the work while learning and they will have many of the tools and equipment that you will need.
This is a good discussion to link to, when the subject of the new body assemblies and relative price comparisons comes up.
Rustytruck
Find a specialty shop that does Bronco repair. They could easily save you half on replacing the rusty sheet metal. Then send it to a body shop for final work and paint. Someone who knows how the Bronco is put together and when and where to replace the rusty stuff can really cut the time. You don't want to be paying someone $100 an hour to learn how to fix rusty Bronco panels. Paint and finish body work is a real crap shoot. It could cost you $2000 to $20000 if your not careful in what you ask for or where you go.
G
guidoverduci
NorCal
Wow! Great info everybody. I can see the potential pitfalls in buying with body work issues. I'm going with buying the best I can afford!
Spray, that's a nice looking bronco, thanks for the pics and info.
I'm in Santa Rosa if anyone has a body / bronco guy to recommend. I'm still continuing my search for the perfect project bronco.
Once again this sight comes through with such great info!
Member BajaBronco here (Andrew) is right down yonder in Petaluma. You might PM or call him to see if he has any body shops he uses, or has experience with.
allenfahey
There are very few shops that work on rustorations. I refuse to work on old vehicles at work. There simply isn't any money in it. Insurance work on late model vehicles are much more profitable. If you can find a shop you can figure about 15 hours for each 1/4 panel (upper and lower) and 4 hours for replacing each fender. Labor rates in auto body is no where near $100 but it should be. It's more in the $40-$50 at the most. Sheet metal is sheet metal, any good body man can work on a simple vehicle like a Bronco.
If you also have them do the paint work make sure to ask them about what you are getting. Are you getting junk clear like UPOL or are you getting the high dollar clear? There is a night and day difference in low end clear and the name brand clears in durability, gloss, and price. Are they going to give you a lifetime warranty? Don't just shop for price. You get what you pay for in auto body!
G
guidoverduci
NorCal
Thanks Allen.
One more quick question... Lets assume I've found a rustless bronco, ha, what's a rough idea on cost for just grafting in front fenders in the rear? I'm not familiar with welding, and I'm not sure how labor intensive that is... But I love that look. Thanks!
clarrance
This is the most realistic answer related to the cost of Bronco body work that I have heard in a long time. This is why the $9000 new tub from Dennis Carpenter makes the most sense. It takes a lot of time and money to have have a decent Bronco body now days.
englewoodcowboy
Exactomundo! If you are going to pay someone to do it the new tubs are worth every cent now...
