Body work ?? Need help with door alignment
broncosport
Knob Noster MO
I cut the rocker panels off My rig and the spot welds popped at the bottom of the front door post. Now the door opening is way huge?? What do I do??
Pedestrian
Bronco Missionary
Pics please. I think I have a similar issue and need to see what you are referring to.
broncosport
broncosport
Knob Noster MO
I'll try to get some up?? What had caused My problem was that I cut the rockers out with the intent of welding in som 2x4 steel sliders but befor I could get to it I step in the wrong spot and popped the welds??:mad:
NGABronco
Always Learning
N. GA now South Carolina
This might help??? Good luck!!;D;D
beaux312
Hartford, AL
sounds like your body sagged when you steped in, put some jacks at the front and back of the door opening, lift up till your doors line up and shut real good, try and put your top on first, it will help support the body. then if you can weld in your sliders or weld a X in your door opening to keep it in place when your move the jacks to weld them in. hope this helps
