adunham
I was driving to pick up my new driveshaft about an hour ago and I heard some funny squealing and rattling coming from the engine. I pulled over and opened the hood - the serp belt had been thrown and three of the four bolts that pass through the fan & aluminum spacer were loose. I got towed back to my driveway and pulled the belt, fan, & aluminum spacer out and discovered the three loose bolts had actually broken off in the steel disc on the front of the water pump. I'm guessing that disc is a press fit on the shaft. I can only see two ways to get those bolts out - (1) take out the water pump, which means I have to take out all of the ac and power steering bracketry, or (2) take out the radiator and try to get a drill bit through the grill to reach the busted bolts. Before I do either one because they will both be PITA's, has anyone encountered this and is there any easier fix?
