Bond fiberglass to steel?
Bitch'nBronco
Bitch'nBronco
Loose Cannon
Ringwood, NJ
No turning back now
Speedrdr
OLD night owl
Paris, MS
@Bitch'nBronco, is the white line I drew where the cut line is going to be? Trying to figure out how far toward the front the scoop is going to wind up. Anxious to see your finished product!
Randy
Bitch'nBronco
Bitch'nBronco
Loose Cannon
Ringwood, NJ
Randy,
Pretty much, I'm going to put a 2" tape line around the cowl and cut so I have a good sized flange to bond the cowl to the hood. I'm going to reuse the pieces I cut off to add structure to the cowl. As for how far forward, im not sure yet. Since the cowl is 4" tall at the back, I need to do some testing with opening the hood to see how far back I can go without hitting the windshield. I'm guessing it's going to start about 2" ahead of the factory hood bump.
Bitch'nBronco
Bitch'nBronco
Loose Cannon
Ringwood, NJ
More progress, im about as far as I can go without starting to glass stuff together. It's a rough draft but I think it's starting to shape up nicely. I love the view of the vent from inside the Bronco. Kind of wish the cowl was maybe an inch shorter but I don't feel like shortening it.
ba123
CA
I like your Raptor influence. That's my daily as well and I used a Raptor Start button...I did have to design and 3d print a holder to make it work but your Raptor influence is a little more involved! Kudos on making it your own!
Bitch'nBronco
Bitch'nBronco
Loose Cannon
Ringwood, NJ
@ba123 that sounds pretty cool, they're great trucks for sure. I wanted to include a little of it in this hood. Excited to see how it turns out, and even more excited to stop making fiberglass dust lol.
Speedrdr
OLD night owl
Paris, MS
Are you going to cover up a portion of the fresh air sections of the hood?
Randy
Bitch'nBronco
Bitch'nBronco
Loose Cannon
Ringwood, NJ
I haven't decided what I'm going to do with those yet. I may just fill them completely since I really don't use either of them. My heater gets fresh air from the cabin (permanent recirculate) and I don't use the fresh air vent. If its hot out, usually I have the top off anyway. The hood has to go to the body shop to get that rust spot fixed where the steel cracked a few years ago, and I may have them delete the vents while they're at it.
bigmuddy
Marthasville Missouri
I wonder how the raptor vent would fit in the scoop on the proflow hood?? Mine has already been painted so I won't do it but it looks like there would be plenty of room unless the raptor vent is hella wide?
Speedrdr
OLD night owl
Paris, MS
Was just curious about that. Could not really tell for sure and certain whether it could be cut to fit inside the vents. Pretty sure the hood could have a 4-6” section be cut out and put back together so the vents are cleared…BUT that’s way more work than I am willing to do. Lol
Look forward to seeing the completed hood.
Randy
Bitch'nBronco
Bitch'nBronco
Loose Cannon
Ringwood, NJ
If I didn't include the raptor vent, I would have been able to keep both the fresh air vents and this project would have been way easier lol. I was thinking about how I could section the cowl to shrink it down a bit to keep the hood vents, but I think I'm just going to fill them, you're right it would be a lot of extra work haha
Bitch'nBronco
Bitch'nBronco
Loose Cannon
Ringwood, NJ
Here are some measurements of just the vent, if you made your own mount for the vent I'll bet it would fit. I asked WH about the pro flow cowl width and they said 35"
If you cut up a raptor hood for it's mount, add about 3" to each side, the total width with the mount is 35.5ish"
Bitch'nBronco
Bitch'nBronco
Loose Cannon
Ringwood, NJ
I decided to recess the vent instead of bonding it to the top of the cowl. Got the top side prepped for glass and test fit the raptor underhood structure. It'll fit, but it needs a bunch of trimming
Bitch'nBronco
Bitch'nBronco
Loose Cannon
Ringwood, NJ
I finished glassing the top and bottom of the cowl. It's really solid and ready for body work. I also trimmed the inner structure of the Raptor hood a little more, I think I'm going to panel bond that in and then glass in the edges.
Bitch'nBronco
Bitch'nBronco
Loose Cannon
Ringwood, NJ
More progress today, not entirely sure I like lol. The vent is body worked in, I decided to wait until I have the cowl mounted to to the hood before I bodywork the center section anymore. It's hard to put any sort of pressure on the sanding block without the fiberglass deflecting.
Bitch'nBronco
Bitch'nBronco
Loose Cannon
Ringwood, NJ
My .02 I think I would taper the front all the way down to the front of the hood somehow.
maybe you were going to do that anyway?
That's the plan, where it is sitting in the picture is where I could get it to sit for a photo without sliding down the hood. It'll be a little further forward and tapered into the nose of the hood.
Bitch'nBronco
Bitch'nBronco
Loose Cannon
Ringwood, NJ
Pulled the hood off and started cleaning spots that needed to be repaired. Few cracks and a bad spot that needs to he cut out and replaced.
