Bottle Jack ton recommendation
tirewater
San Francisco Bay Area
I'll toss in my recommendation of the FJ80 Land Cruiser spiral bottle jack. Lightweight & no hydraulic fluid to leak out. I was impressed with it on my LC - although it does require handle. Discussion on expedition portal on bottle jacks.
Whatever jack you get make sure it collapses small enough to fit under an axle.
Here are the specs (copied from elsewhere):
"Make/Model of jack: OEM Jack from FJ-60/FJ-80 Land Cruiser
Mechanism/ Style: Bottle style double extension screw jack (non-hydraulic)
Collapsed height: 7.5”
Extended height:16.5”
Weight rating: 3968 lbs. (1800kg)
Stability when extended: With base on a hard surface, there was minor slop (1/4”) at the top when extended.
Other key features: The round top had a curved impression to seat on the axle tube.
Final thoughts: High quality, sturdy jack."
This is what the kit w/ jack looks like:
ntsqd
heratic car camper
Upper SoKA
Looks like the same mech. jack as in my '84 Xcab Mini "Patch" & in my former FJ-60. Tool kit looks identical the 60's kit too.
tirewater
Heh, it's probably the same kit that the 200 series comes with as well. Although they don't have a front axle to put it under.
In reviewing the thread, with keeping it Ford in mind, the F250 jack looks nice as well. If it's covered, (& oiled) it should weather well enough for years. Plus it's cheap.
PNW
Cool thing is this one extends about twice as far as a 2 stage hydraulic...
