So, what is the cause of my bouncing speedometer needle? It ONLY does this at less than 30 mph, at any speed above 30 it is smooth as it should be. Cable? The unit itsself?
the head could also need a tune up. classychassisrestoration.com does a great job servicing and updating these old units. kevin is also a member here known as Fallingdown.
Most likely, your speedo cable needs to be lubricated. Disconnect the speedo cable from the back of the speedometer, and pull through the firewall. You can buy speedometer cable lubricant at almost any autoparts store (I know Oreillys sells it). Tell them you're looking for graphite lubricant. It is just graphite suspended in a solvent, to help wash it down the cable housing. Do not use oil, WD-40, etc. It will make the problem worse.
I had the same problem, and used lots of that lubricant on my old one... The problem could not be solved though because there was just too much gunk in my cable. I had to buy a new one.
NOTE*** it might be a good idea to get some carburetor spray cleaner and just spray that stuff down the cable and loosen all that gunk up. Just be sure if you do that, that you disconnect the other end of the cable from your transfer case, because you don't want that stuff leaking into there.
I believe you're correct... but I don't think if that was faulty, it would result as a bouncy speedo needle. That indicates something getting binded & released..
Bulletman: Does it bounce up to a certain speed? Mine bounced up to about 40 mph and then stopped.
