What is long fiber grease? Thanks
It's what used to be considered as "normal wheel bearing grease" back in the days before moly grease came out for disc brake applications.
It's very sticky and is perfect for dampening the torsional wind up of the mechanical speedo cable.
A customer complaint of a jumping speedo was very common on a repair order in the 1960's, I think I did at least "one a week" in the Ford dealership.
I still have my hand made speedo cable wrench. It was a 3/4" cheap box end, cut down to about two inches long. The box end was cut open to allow the wrench to slide over the cable. It works like a tubing wrench. The short wrench gave you just enough leverage to break the hex nut loose with your hand in a awkward position up under a dash.
