bouncing voltage meter
ca1a73
When my engine is running my voltage meter is bouncing up and down,, What would cause this? loose connection? battery connection? any i deas?
70_Steve
Old Guy
If you're looking at the stock gauge in the cluster, it's an Ammeter. Measures current flow, not voltage. Not that that really means anything about your question. The bouncing is the mechanical voltage regulator keeping the proper charge on the battery. Points open... points closed.... points open... etc. If you don't like the bouncing, I've read that you can replace the mechanical one with an electronic one from a 78 Granada.
feitctaj
FNG
Group W Bench
A bad diode in an alternator can cause this too. I have one sitting on my shelf as my spare , it charges just fine , just drives me nuts with the needle bouncing.
I have put it on about 3 different times over the years," oh yeah , I remember this alt"!!!!
Change to a new one and poof, no bouncing needle!
C
ca1a73
I have a cheap aftermarket guage for the volt meter. Its not the stock one. I never had a problem with it moving before. Only thing i did was move my dash to install defroast ducts. Could i have hit a groud wire or something? Or chases are its my alternator? It drives me nuts.
Bronco_46256
Elkhart
The Grenada regulator worked excellent in my 75----no needle bounce at all and no headlight flash.
When I tried to put one in my 68, the needle bounced so hard, I coild not see it. Only thing I can figure is that the meter is so sensitive in the 68 that its picking up all the little on/offs in the electronic regulator. Needless to say, I switched back to the mechanical for the 68. I would still recommend going to the electronic, though.
4xfloored
San Bernardino
When you say regulator, that is Voltage.(right) and my 73 has a very active needle too and I get the flicker in the headlights... will that Granada regulator solve both of my problems??
HotWheels
Twilight Zone
There are two versions for the Grenada. You need to ensure you get the slimmer (solidstate) one instead of the mechanical.
