JaxLax
As always, long post incoming, but I want to give as much background and specifics as possible. Fast forward to CURRENT PROBLEM HERE below to bypass story time.
Last time I drove her a few months ago, on the way home, idle was fine and smooth after leveling back out, but under accel it would bog down and at higher speeds often felt like it was missing cylinders or just running super rough. So I parked it and put on the cover and said I'd get to it when I could.
Yesterday, the boy and I had a day of nothing so we decided to go after it. Got out there and tried to turn it over - nothing. Popped the hood and found the battery at 0.40V. Yanked it and plugged in the charger. Came back 30 minutes later and set the charger to 75a starting and it wouldn't crank, but not turn over. Also during charging we noticed an electric sound behind the dash. After an hour of other chores and we took the battery off the charger and watched it lose voltage sitting still - so we went and got a new battery. Swapped it out and kept moving forwards.
Now the engine was again cranking, but never turning over. Fuel in tank, fuel at the glass filter would bubble/move at crank, but getting nothing in the bowl. So we pulled the old filter at the carb and it was HEAVY. Swapped it out for a new one (that you could see through into the screen) and a few cranks later she fired up for maybe a half second. Then died. So I pulled the multimeter out and started checking the ignition system and quickly found out the coil was way off spec on both the first and second windings. Went to the store AGAIN and got a new blaster coil. Got it in with some alligator clips to test and she went right over on the third click, but faded off. Fine, it's been months. Had to keep going a time or two (note: there were some stumbles here, but I thought it was due to maybe carbon on the plugs/sitting issues). Let it idle for maybe 10 minutes and it burned off some oil and the smoke cleared out and she sounded fine.
Went to take it on a test cruise. The issues still remained. Idle/coast is generally fine after a few seconds, but accel or speeds above idle are rough and feel like it's skipped cylinders/fouling? So we're a half mile from home and it straight DIES at stop sign. Pop the hood and nothing looks/sounds/seems wrong. Figured I'd just give it a couple of minutes to settle/cool down. Next start turns over and then fades off at idle. For the next 30 minutes or so we go from starting to no idle fades in between me pushing it 25 yards.
Items replaced: battery, fuel filter, ign coil.
So during the idle fails I noticed that with my key in the ON position my tach is bouncing all over the place (0 to 1500 to 400 to 2000 to etc). When I remove the ignition system from the overall electrical system (this truck had 3 kill switches I've removed, but this one I couldn't trace so it remains) with a kill switch and leave the truck in the ON pos the tach correctly pegs to zero. When it does start and run the tach does bounce like before (all over the place).
There was a time about two years ago when this was my daily and all these systems worked fine and well w/o issues. I understand the battery/filter being almost considered consumables. The coil is old and for all I know the ign box and volt reg are stock. So have they just finally given up?
Going to search now, but wanted to see if anyone had a definitive idea or solution to this problem before.
