Bracket change for 351 w alernator
tw322
Ok so while in the middle of changing out my alternator I decided to buy new brackets cause they needed to be replaced. So while changing them out the top bracket (top) bolt won't come out. I then realized the fan and entire assembly has to come off just to get the bolt out. So here is my stupid question....do I have to really take the radiator out , the fan assembly apart just to get the alternator bracket bolt out?
tw322
tw322
Unfortunately not. I took the fan off but the shaft has a large counterweight? that won't let me take the fan off and it's too close to the radiator so I would need to pull the radiator to access it to take it off. I think I know that that will be the answer but I was hoping for an easier solution.
tw322
tw322
I will take some today and post them this afternoon.
tw322
tw322
Damn! Forgot to take pictures before I left for work last night. I will try to remember today and post later but the alzheimers may impede that.
tw322
tw322
Hahaha...I must have it bad because I still haven't remembered. I work nights and when I leave the house for the drive in, thats when I remember. Fortunately I am off this weekend so I will most likely remember then.
Is there a reason you feel you need to replace the brackets in the first place?
Old ones rusty or bent up? Don't like the design?
Just curious, since I'm thinking new brackets aren't usually a service-replacement item when just changing out an alternator.
I'm interested in seeing pics too, since I can't picure what would be in the way of the upper bolt. Not that I've done one recently, but it's hard to picture.
