Bracket on passenger side quarter panel
Wrose2
I've recently looked at buying a 69 bronco. There is a small metal bracket bolted on the passenger side rear quarter panel above the wheel. At first I thought it was something someone added on over the years. But, now I've found this same thing on a couple of Internet images, so I'm thinking it was original and there for a reason. I'll try to upload an image if needed. Any information will be greatly appreciated. Thanks
thegreatjustino
Red Head Grease Monkey
Stockton, CA
If you're talking about the one on the outside attached with four bolts and one large bolt in the center, it's a ranch hand bracket for the tire carrier. It allows you to latch the stock tire carrier to the side instead of to the tailgate.
toddz69
And is more commonly found on '69s than any other year.
Todd Z.
hammer189
South Atlanta
If it's the one inside the wheel well, mine had 1 on each side. Looks like a round bar brace with flattened ends for attachment. Just in front of the rear wheels. Vendors sell them. I'm going to replace mine when I get the rest of the body work done. David
chuckyb
Ranch Hand Bracket
AKA ranch hand bracket. I have one original on my 68. Learned on this site that the original finish was a dull cadmium. Seems they appear on 68 and 69, not sure of other years.
