brake conversion question/ corvette master cylinder
bronconut73
Has anyone done the brake conversion using gm brakes and an early model corvette master cylinder?
I think that Vette mc was what everyone was using with the four wheel disc set-ups for awhile. It seems that conventional wisdom is that you don't "have" to use that mc now. In fact you can use the stock eb mc with residual pressure valves removed from the ports. But mc are so cheap you might as well grab a new one.
I always liked the Vette double bail for the mc lid. Seems like it would reduce leaks in rough terrain.
frenchy
Hey shamu are you power or manual brakes? I like that master.
frenchy
wesleydax
im using a vette mc with gm rear disc and j-10 jeep front disc. Its fun going to auto zone to get parts;D drives em nuts
D
dmsbronco
West Hills
I've installed the mc, but brake pedal is too high, is there an adjustable rod from pedal to mc? In addition I was given an extender that fits into mc, but the plug doesnt allow enough space to have the rod resting inside the hollow of the mc.
wesleydax
there are adjustable rods out there i think summit has them. not sure what you mean by the plug.
shamu
Lucky as the day is long.
Sachse,Tx
D
dmsbronco
West Hills
Got it all together, My biggest issue was proper pedal height, and all I had to do was lengthen the brake rod.... A couple of trips to home depot for some threaded rod, a couple of nuts and threaded adapters... the rod is now adjustable, and working
