I've been struggling with the stock brake light switch for a long while and finally found an opportunity to upgrade. The OE "spring-loaded lever style" of brake switch worked great for the original EB with antiquated brake systems and lots of pedal travel. However when you start upgrading your brakes, such as modern 4-wheel power disc setup, the pedal movement required to stop or slow often is minimal and the OE switch doesn't have enough range or sensitivity to function correctly. This would often leave me with the brake lights not coming on correctly, or adjusting the switch so they would, then having them stay on without any pedal pressure. I've messed with this for months and used different OE switches, etc.
What I did to fix was move to a more modern style push button switch. I then fabricated a 1-piece bracket to hold the new switch a little lower on the pedal in order to detect more sensitive movements. Finally I bolted it to my existing pedal box to finish off the installation. So far with some initial testing the new switch works flawlessly and has plenty of adjustability built right in. Here are some pics...
