Brake line banjo bolt question
MrT
I have a 1978 F-150 high pinion dana 44. I put on new calipers and I had already ordered brake lines for a 1977. When I was putting it together I noticed the banjo bolt was pretty loose in the brake line. I decided to return the lines for the 1977 and ordered the ones for a 1978. Well these have the same problem(if it is one) I would guess 3/8 banjo going through a 7/16 hole in the brake line. I am use to these having a closer fit.
Should they be loose? I talked to JBG and was told there is only one caliper and these are corrd t lines. On there website they sell a banjo bolt that covers many years. The copper washers could seal it up but is everyones like this?
I also noticed you can get a caliper with plastic or stainless pistons. Maybe they use a different bolt size?
M
MrT
I looked but didn't have any luck finding a bolt like that. My battery is dead in my caliper I will get a accurrate measurement asap.
Thanks!
NicksTrix
the bigger piston calipers are a 7/16 thread usually a odd ball 24 tpi count.
the bronco 76-77 calipers with the small pistons have a 3/8x24 thread. you obviously can't mix and match lines and banjo bolts
summit and speedway are both sources for the 7/16x24 bolts
mrdrnac
Any Chance you have the T-Bird larger piston calipers on their? They use a larger 7/16"x24 banjo bolt instead of the 3/8"x24 banjo the regular Bronco uses?
Typed too.....SLOW! BC Broncos also has the Banjo bolts.
M
MrT
It sounds like I have calipers for 76-77 even though the part number matches a 78? The holes in the caliper are 3/8.
What do I order for to get the 7/16 thread? 78 from somewhere else? I wouldn't mind switching because these have the plastic pistons.
I have the 3/8 banjo bolt on the caliper, it is too small for the brake line. It's too small for both sets of lines I bought.
M
MrT
It looks like the JBG front conversion disc for 66-75 use a 7/16 banjo bolt. It also looks lime the Thunderbird calipers use a 7/16 bo.t. I wonder why JBG lines are 7/16 if the norm is 3/8? I think going to Thunderbird calipers would fix my problem.
toddz69
If you're ordering from JBG and the lines don't fit, why not return them and purchase them from another vendor? That would be the easiest, wouldn't it?
Todd Z.
M
MrT
Todd Z.
I want to know what's going on so I can get what I need wherever I get them from. I already have the center rear, outer rear and front center that all match. I have the fronts that match if I can get a caliper with a 7/16 bolt. It sounds like the Thunderbird calipers are considered a upgrade so that's what I will do unless I hear different.
unimogger
Philthadelphia
I just used thunderbird calipers. Had to drill the 77 hoses from 3/8 to 7/16 to make it work. The calipers don't usually come with the banjo bolts, so order those separately as well.
M
MrT
Thanks, that's what I will do.
