brake line banjo on diff hosuing specs
cruizin
hi guys,
i'm fabbing up some new brake lines using AN fittings and was wondering what the specs are for that banjo bolt mounted on the top of the front and rear diff cases? looking to get some adapters to fit to that so I can run my 3AN line in. actually, i think it's just the front one that uses a rubber line in that i'll need it for... anyone know what the thread is on that... 3/8 24?
thanks.
NicksTrix
you'll be better off tapping the block for a -3 1/8 pipe nipple rather than running adaptors.
Apogee
Tangent, OR
The fewer the connections the better IMHO. Any reason you're not just using a (3X) -03 Male AN T-block and AN hoses rather than adapting from SAE inverted flares to AN? I've always thought that if you're going to convert to AN, do it everywhere and be consistent. The only place that can be difficult is at the master cylinder.
