Brake Pedal Height
syndicate1
Need some insight from all the gurus here..... I recently added a brake booster to my disc brake setup. After installing the brake booster kit, I realized that threw away the old stuff (push rod, etc...) and forgot to set the correct pedal height using the old push rod. Now the pedal is so high that I can’t brake without lifting my foot off of the floor to get on top of the pedal, Ughh!! I miss the brake pedal being aligned with the gas pedal. Does anyone know the correct pedal height measurement from the floor to the bottom of the pedal?
xltboy
i found that 6.5 inches (face of pedal to floor) will allow the master cylinder to bottom out just before the pedal reached the floor.
Xltboy
S
syndicate1
Xltboy
Thank you!
75MIKE
NE Washington
Nope! That’s the problem... I forgot to adjust the pushrod.
So you separated the master cylinder from the booster and adjusted the plunger so it's a hair from touching the master at rest. If you are talking about the pushrod that goes from the brake pedal to the "hinge" in the booster bracket.
No way to adjust that unless you have one of these:
https://www.tomsbroncoparts.com/product/power-brake-pushrod-66-77-early-ford-bronco-new
S
syndicate1
Thanks! I have the WH brake booster and bracket that comes with an adjustable pushrod.
