brake warn lamp on '66?
birdman
Napa
I am doing a centech rewire and I am struggling with the brake warn lamp set up. I have a hazard lamp but no brake warn lamp. Are these two one and the same or did the really early broncos not come with a brake warn lamp? If they didn't come with a brake warn what do I do with the wires that I would have used for this?
Scoop
Bronco Old Fart
Cuchara, CO
On EB's, the brake warning light indicates the differrence in pressures between the front and rear brake systems as pressurized by the dual reservoir MC. 66's have a single reservoir MC and thus did not come with a sensor or a brake warning light. My 66 did come with hazard lights.
You can simply leave the brake warning light wire unused. I would crimp on a cap or otherwise insulate it though so that you don't have a short when the wires move around.
B
birdman
Napa
Thanks, I thought this might be the case. Although I have 2 MCs which I do believe was an aftermarket item put on by the PO.
