Ignition switch isn't grounding brake warn light
fromme
Suffolk, VA
I got around to finishing the wiring on my Centech harness to the brake warn light. Connected the prop valve and the warning light and the ignition switch. Problem is that the warning light does not come on during crank like it should. I have done some trouble shooting and found that there is power to it, the bulb is good, and if I jump the connector at the prop valve to ground the warning light does come on like it is supposed to. So I know I have it wired correctly and the power and grounding is there.
Any ideas as to why the ignition switch isn't grounding the light like it's supposed to during crank? It is a brand new switch assembly that I got from Toms. So I figure it should be good. What's the chance I got a bad one out of the box? I looked through the factory service manual and it shows the switch body is grounded to the dash so I wonder if maybe there isn't good contact there. I don't exactly know how that ignition switch connects a ground during crank. Any ideas?
fromme
fromme
Suffolk, VA
I'll also add that I clipped one end of my test light to the ignition switch terminal for the brake light test and probed a positive wire. Then I cranked the engine to check it and still no joy. So I definitely know there's an issue with that switch. Just can't determine if it's an internal problem with the ignition switch or if that body needs to be grounded better.
Viperwolf1
electron whisperer
The ign switch has one terminal (c-242) that grounds to the switch body in START. No connection in any other position. That terminal is for the brake light test. Check to make sure you have the wire connected to the proper terminal. Test the switch with a voltmeter or ohmmeter.
fromme
fromme
Suffolk, VA
Yes, that is the connection that I tested with a light. It is not grounding in start.
I suspect that the body isn't grounded, and I can't figure out why. Have a hard time believing the switch is bad.
oleguy74
calif city ca
on stock sw's,there is a term labeled P or prove out.if yours has this,connect ohmmeter to P term and shell of sw.if you see contitnuity your sw is good.
fromme
fromme
Suffolk, VA
I'll do this tonight, it's not too hard to remove the whole assembly. I have a multi meter, but never ohmed anything out before. What kind of reading am I looking for?
Viperwolf1
electron whisperer
Resistance is the opposition to current flow, measured in ohms. Less ohms is more current. It should be very close to zero ohms for a good connection. Unplug the connectors before measuring. If you measure a hot circuit with an ohmmeter you could damage it.
fromme
fromme
Suffolk, VA
I will remove the whole assembly and the connectors and then ohm it out. At least then I'll know if the switch is bad or if the switch body isn't grounding to the dash. A lot of worrying about a stupid brake light test circuit though, isn't it? :p Oh well, I like all my junk to work like it should, electrical things drive me nuts, and this is the last thing I need to fix.
iwlbcnu
Just to make sure, this terminal is the one all by itself on the side of the switch, not in the cluster plug.
fromme
fromme
Suffolk, VA
Yes that is the terminal.
Thanks all, I got it out and put the meter on it. Believe it or not it is the switch, bad out of the box. Turned the key to start and checked the terminal to the body and got nothing, meter doesn't register anything. Called Toms and they are send out a new one, those guys are great. I'll check the new one before I put it in.
fromme
fromme
Suffolk, VA
Confirmed, it was the switch. Replaced it today and all works as it should. Thanks for helping me diagnose this, and now I know how to use my ohmmeter too.
