brazing/soldering oil pan?
Scott M
Baltimore
got a .5" split in my oil pan (yeah, i put in a new oil pump and didn't put clay in to see if it would hit, although i did test fit it and it seemed fine, but by the time i torque the thing down it just barely punched thRu). just rehung the thing and would like to avoid pulling it again.
anybody got any thoughts on cleaning up the are real well, cleaning it w/ acid and soldering it w/ some rod and a one of those little butane bottle torches? type of rod to use? think it'll hold?
mtkawboy
Billings Mt
I did the exactt same thing on a 351 motor out of my van. Got a car pump or something and split the pan bolting it down. I drilled a small hole at each end of it and brazed it up. That was 10 years ago and its still working fine. Soldering I dont know anything about but dont think it would have the strength
wildbill
Old Bronco Guy
:p :p :p I would not solder it but brazing would be fine good luck. :cool: :cool: :cool: Bill :p :cool: %)
Gummi Bear
If you have the resources, TIG it.
I've watched folks Tig some really thin metals, and if the welder is pretty proficient, you won't have hardly anything to clean up with the flapper wheel.
cracker
Pueblo, Colorado
You can braze the spot, but I prefer using like metals to fix anything. If you have access to anyone who can mig/tig it, then that is what I would do. If you don't get weld right with the braze, you will develope a leak.
