Brazing
JHD
Colorado Springs
Has anyone used brass brazing rod to fill holes in the sheet metal. I just learned how to do it and I am pretty amazed at how easy and fast it is. I had tried filling some small holes in the tail gate with my mig and made a huge mess and did some serious warping. Last night I filled and ground 6 of the stock tire carrier holes in under 30 min. I know it's a softer metal but does that make any difference on small areas like this?
broncomaster
Edgewood,Wa
I would think brazing on sheet metal would cause much more warp to the metal. you have to heat it up to cherry red. with my mig I zap it on and off and hardly ever get metal warp on hole repair.
Skiddy
I don't see a problem with it as long as it doesn't warp, has to be better than lead that they used years ago.
bluebronco69
Damascas, OR
i agree on mig the problem you probably had was a soft area due to rust so it keeps burning through easily, which is a problem with welding old sheet metal, if brazing works for you then im sure it is fine but i bet will warp thinner metal easier, with mig, just take it slow and dont weld large areas or beads at once on sheet metal and you wont get the warping
Fishbone
Northern, Illinois
I haven't done any, but I know it's a pain to weld near anything that's been brazed. Someone brazed galvanized sheet metal over the rusted floors in my EB, what a pain in the a$$.;D Cutting the rust out is a big enough pain, but getting rid of the brazing was just as big a problem, maybe worse.
Having said that, filling old bolt holes like you described should be fine. It's gotta be better than putty. I'm like some of the others though, I'd be a little leary of heating my sheet metal that much. I haven't done it though, so maybe I don't understand the process as much as I thought I did.?:?
thegreatjustino
Red Head Grease Monkey
Stockton, CA
I've seen it done lots of times. Personally, I would rather mig them closed, but there is nothing wrong with brazing. As for the metal warping, when brazing you just get things hot enough for the brazing rod to melt into the area that you are brazing. Since brazing is a mechanical bond and not melting two pieces into one like welding, you don't need anywhere near as much heat. At least that is the way I learned how to braze.
JHD
JHD
Colorado Springs
It did warp the pannel a little but far less than the mig. Maybe I was going to fast with it. I really like how it came out though. I'll post some pics this weekend.
br0nc0xrapt0r
Loves pickles
dude I am so sorry I didn't read this earlier, I just erased the episode of muscle car off of my dvr where they had brazing with a tig that wont warp, damn.
Madgyver
Bronco Madman
The trick with a mig is to go slow, a tack at a time. Use a copper backing to close the hole from the other side and use the mig slowly at a low setting enough to grab the sheet metal. Don't let it stay red too long, this will cause burn through and warpage.
A good copper tool is a 1 foot piece of 3/4" or 1" copper pipe. Flatten 4" of one end and make a curve on it to match the panel that you're working on.
There are certain times when brazing is good to use but I'd go mig to fill holes. And if the holes are too big then I'd fab a small patch to fill it and then mig it on..
fordtrucks4ever
DFW
A block of aluminum works just fine for a backup when using mig too. It draws the heat out and will keep warpage to a minimum. If you clamp thick aluminum plate on one or both sides of a repair, the pieces can be butt welded together without any burn thru or lift. This is how I welded front fender openings in the rear for a factory stock look without any obvious alterations on the backside.
NicksTrix
i use a silicon bronze rod with a tig in certain areas. works well esp when i can't get a backing block inside (say a windshield frame). key is controlled low heat.
Ohio Bill
Riverside, OH
Use the smallest tip you can for your outfit. Keep the flame very low and you can braze all day with out warping. I have brazed for years on sheet metal and you just have to practice and control your flame keep the heat a little more on your rod than the metal...is the tip
Ohio Bill
Riverside, OH
I have also used bronze wire with argon to fill holes too. I like the idea of copper backing to pull heat and flatten the weld. If you decide to try the mig use the gun in a skirting tigger manner. You'll do just fine. Remember pratice on some scrap until you are happy with the look.
firehawk
Clawson, Michigan
Tig with the rod looked like a great way to go. It uses less heat to melt it. But then you need a tig welder. I guess it all depends on your skill level. I would think the mig would be easiest. But all methods have worked for years and still will. Good luck. :)
JHD
JHD
Colorado Springs
This is the first set I did. I have filled two other sets but haven't had a chance to grind (the little one's room is right above the garage). The two other sets came out alot better. I used a lot less material and I don't think I warped any metal. I'll have to wait until I grind it down to tell. If you look close at the top hole you can see that I let it get cold but like I said I think the others came out much better. I post the rest of the pics tomorrow if I can finish grinding tonight.
eds66bronco
Essex, Vermont
do yourself a huge favor and get a flap wheel sanding disk for your grinder. they look like overlapped pieces of sand paper formed into a grinding wheel shape. they don't gouge the metal and leave a nice smooth finish. nice job by the way. i do think the mig will heat way less area if you used a low setting and .025 wire
Flintknapper
Deep East Texas
Exactly!
I have filled many, many.. holes and cracks this way. It's "old school" to be certain...but it works well.
Heat the metal on the panel only enough that it will "accept" the brazing rod when it begins to flow. It takes a little practice, but doesn't warp the panel if done correctly.
