I have a 75 with a 2.5 SL that im trying to get back on the road after 23 years of being a deer camp and mud truck. Im going with the factory setup. i have a new adjustable drag link, new tie rods and soon to order an adjustable track bar. Once i pulled off the track bar that was on it, i noticed that the PO had some issues with the lower track bar mounting bolt. it seems that the weld on the bolt had broken off so he cut the bolt out and used a new grade 8 bolt with a nyloc nut going through the bracket backwards. this doesnt seem safe to me and it will not hit the road before its fixed. the track bar is about 3/4" low on the axle end to being parallel with the drag link, and if i weld on a WH or Duff track bar riser bracket will the track bar rise too much and create bad steering? Any other suggestions.
thanks
thanks
