Broken tailgate cable????
agduckhunter
One of my tailgate cables must've snapped. When I pull the lever, only one side of the tailgate releases. How big of a pain in the butt is it to repair/replace. I assume the tailgate will have to be disassembled? Can anyone point me to a step by step?
doghows72
It's not a cable but a rod. Simple fix but you will need to take most of the tailgate apart.
CopperRanger
Not sure about a step by step, but a few years ago I replaced the piece behind the handle. Putting the handle back on is a pain. I read somewhere on here to wedge the latches on each side inward with a couple screwdrivers when reinstalling the handle, worked pefectly. That lines up the handle correctly. Hopes this helps when you put it back together.
Whoaa
99% of the time the carter pin comes out of the hole holding one of the rods. And thats why one side still works and the other side doesn't.
Fixing it is not a "hard" job, but does require patients.
Remove the 2 bolts on each side of the tailgate hinge and then take the tail gate off. When putting the tail gate back on the alignment is done by adjusting the hinge plates up or down to square the tailgate in the opening and make sure it is the proper distance from the top hatch for a good seal.
You'll need to remove the tailgate. Carefully remove the latch, remove the one rod thats still attached and secure it w/ a long piece is wire, so you can pull it back up to the hole when you're ready.. Then fish the other rod up to the hole where you can see it. Reinstalled both rods w/ new carter pins, and then put the latch back together. The latch has to have some spring-tension by way of jamming a shim in the striker to allow you connect the rods. The correct orientation of the latch can be tricky, often times its a trial-n-error process to get it to work properly and fully retract.
If the bolt is rounded off, you'll need one of these http://www.wildhorses4x4.com/product/Tailgate_Handle_Pivot_Bolt
Often times when the tail gate is off this is a good time to get rid of one more rattle by using new bushings for the hinge. http://www.wildhorses4x4.com/product/The_Silencer_Tailgate_Hinges
