DJs74
- Apr 1, 2014
- 1,135
Would you happen to have a spare carburetor laying around or maybe a buddy has something in the 600 to 700 CFM range that you could simply bolt on and try.
I personally have zero experience with Edlebrock carburetors... Heard they are great / heard they are junk but I couldn't say one way or the other. I was thinking along the process of elimination lines with the carb... If it exhibits the exact symptoms with another carburetor, you can have confidence in the Edlebrock and go deeper. If your symptoms get better, worse or go away altogether then you've made an impact.
For now... I'll stand by my original diagnosis of a vacuum leak and I think there needs to be some timing adjustments made as well.
One question which may have been addressed previously and I missed... Do you know what camshaft is in it? And how does it sound, lopey... smooth... Etc? I ask because the camshaft itself could be creating a vacuum leak by way of the valves not fully seating during the firing event. If the valves are adjusted on the tight side and they are not fully seating, you can have a vacuum leak between the intake / exhaust valves and never...ever find it from the outside.
DJs74
DJs74
