Bronco Graveyard Rad Hoses
TTownEP
Has anyone used these radiator hoses, meant for the Mustang motor swap, on the Explorer motor swap with factory Bronco radiator?
It looks like a similar water neck orientation, but does it jive with the Explorer brackets?
There seems to be a ton of people making Frankenstein hoses from a list of different hoses for other vehicles, but never see this mentioned.
https://shop.broncograveyard.com/V8-EFI-Radiator-Hose-Kit/productinfo/10642EFI/
jmhend
I used this kit with a Champion Radiator with the top port on the high side of the passenger side and the lower on the drivers side. I can dig up the part number if neccessary..
Jason
Sent from my SM-N960U using Tapatalk
toddz69
I used those Mustang hoses when I had a Ron Davis radiator(s) years ago with the swapped inlet/outlet for the 5.0 swap. Worked great with the Explorer bracketry. I don't recall if the hose ends on the Bronco radiators are the same diameter as those hoses or not.
I still have a Mustang top hose sitting in my garage that you can have for the cost of shipping if you're interested....
Todd Z.
TTownEP
TTownEP
I did finally get in touch with someone there, and they could not confirm fitment for the Explorer front dress.
I do now see that I am barking up the wrong tree. This goes from the water neck to the passenger side of the radiator, and I need one to go to the driver's side.
I may change course here, and do the Frankenstein route like everyone else. None of my local parts houses have the usual hoses in stock, so I figured if I had to order it in anyway, may as well check every option.
jmhend
Yes sorry. I think I thought you were running this to the passenger side. I do think I have seen a few buddies that have ran theirs to the drivers side. Let me see if I can get a picture and part numbers to post for you.
I know people have done it.
