Bronco Hunting
Schloer2
I am a noob that is headed to check out a 1977 Bronco on Sunday. Seller says it was a running/driving/licensed rig in 2002 when he parked it in his barn and it has not moved since. I know what to look for in terms of rust, but am by no means a mechanic. Any recommendations on what to check on the drivetrain to indicate whether it can be brought back to life with new plugs/fluid/fuel? The odometer shows 86k miles, but the engine is actually a newer 302 out of a mid-80’s Mustang ( unknown mileage).
Also, is there any risk with clamping on some jumper cables to quickly check if any of the electrical still works?
Thank you for any words of wisdom...just trying to avoid buying a rig and then sinking $$$$ into the engine.
KyleQ
I wouldn't hesitate to put jumpers on it. I would pull the coil wire off and crank it for awhile before you start it though- check fluids.
Kyle
Crawdad
Be careful the tank might be full of sludge. If it turns then that's a good sign. May blow some smoke but that's to be expected. "Should" clear up with oil change and new gas. Just want to make sure engine is not locked up. Manual tranny usually do well if sat for long periods of time, can't say the same for autos.
Schloer2
Schloer2
I wasn't planning on trying to fire it up. Just try to turn the engine manually and check the oil to make sure it isn't dry. I figured I would throw on the jumpers just to see if any of the lights/signals/horn/wiper motors/etc were in working order. Unfortunately, it is an auto trans...what do I need to be concerned about Crawdad?
beernut
Hampton
Mostly oil turning to sludge, valve body becoming gummed up, maybe the torque converter. Really though, the ford c4/c6 are easy to find. I don't believe you'll have any problems with the transfer case as long as it shifts.
half cab
Guru Bronco
I would think that C4 would be ok....If everything was buttoned up and not exposed to the weather as long as it was ok before parked...
Spartan
Backwoods, KS
That was my thought as well half cab, ex. If windows were missing and it sat outside in the Minnesota winters etc
Schloer2
Schloer2
In IL in a shed with concrete floors. Hardtop and doors all in tact. Only real rust issues seem to be rear quarter seams and passenger floor pan.
Spartan
Backwoods, KS
Should be pretty clean then as long as the varmints left it alone lol
May not be a bad idea to prime the oiling system after you change it so you know there's oil in the top end prior to it cranking/firing it.
You'll need to rebuild the carb.
Also the trans may leak at first but *sometimes* the seal can swell and seal again (as long as they're in good cond) after you change the filter/fluid in the trans and start driving it again.
You'll def want to change the diff fluids and t-case fluids, theres probably condensation in them that has created a thin layer of surface rust.
Axle seals will probably leak, *probably*, as well as most gaskets/seals but its really not that big of a deal as long as you're willing to get dirty lol
Schloer2
Schloer2
Thanks everyone for your insight. I have been searching for over a year now and hope this is finally the right rig for me.
half cab
Guru Bronco
Good luck with it and keep us posted.
If priced right and you get man you know this site can walk ya through any issue that might come up....;)
sprdv1
REBEL
Patience is key.. The right one will come along for ya
broncosam
Before I bought my first Bronco, I went to look at one in Tennessee, it had been sitting awhile. First thing I did when I opened the hood was to pull the crankcase dipstick, it wasn't pretty. The stuff on the dipstick was milky and smelled of gas, I passed on it.
luke
illinois?! thats my country. where is it? where is it? where is it? just kidding. good luck. hope you get a good one.
Punisher
Well if you do get it no matter what shape it's in if the bronco bug bites and it usually does plan on sinking $$$$ into it anyway. :)
Good luck.
Schloer2
Schloer2
A couple teaser pics - obviously gonna need some wheels/tires
