bronco pulling badly to the left?
mauibronco
howzit you guys.
i have a half cab with a 1 in BL and 2.5 susp. and 33in tires. the front end is very tight but it pulls very strongly to the left....i thought that it might be an allignment issue but my shop says that allignment doesent fix "pulling"?? i thought that was one of the main purposes of an allignment...anyway, does anyone know or have any ideas as to what the most common culprits of this are? thanks much!
Timmy390
Conway, AR
howzit you guys.
Find a new shop......I've knocked the allignment out hitting pot holes and it cause pulling....the allignment shop corrected it......
Check the toe....Could also be a bad ball joint(s) or tie rod.......
A proper allignment shop should be able to tell you what's wrong but checking yourself is cheaper. Just a note, the only thing they can change at the shop is the toe-in. You have to add sleeves to the ball joints and differnet degree C-bushing to do any other corrections but they should be able to give you the allignment numbers which will tell you if you need the above.
Tim
dube
big lake Mn
if its drum up front, i had a bad wheel cylinder that was not working so it would pull real bad
Justafordguy
X2, your alighnment shop is wrong. Improper alighnment can cause a vehicle to pull but the first thing I would check is your brakes and wheel bearings.
surfer-b
Like others stated check your lft front brake, sounds if though its dragging
sp71eb
North Liberty, Ia
I would check the brakes. Drive it a bit and carefully feel both front rims, if one is hotter than the other its most likely a brake dragging.
Apogee
Tangent, OR
When does it pull to the left? Under acceleration? Braking/deceleration? Bumps/potholes? Always? Knowing when it pulls to the left would help diagnose the possible causes.
Any funky tire wear?
M
mauibronco
thanks so much guys for all the great suggestions! Apogee, it pretty much pulls the entire time. accelerating, decelerating, even going 5 miles an hour in a parking lot! As far as the brake suggestion, i have a 77 front end with disc brakes..
mahalo nui!!!!
dube
big lake Mn
you have any pics of a front end shot. striaght on. the only thing i can think of is the caliper is stuck. take the wheel off and depress your caliper see if it is working right.
Apogee
Tangent, OR
Best guesses, stuck caliper (piston or slides), seized wheel bearing, or something serious messed up with your alignment. I don't think you'd notice a seized rear axle bearing from a pulling perspective, but it's always good to keep an open mind when trying to figure something like this out IMHO.
Mr. Lav
due you have a copy of the alignment? if so can you post it. if the shop is just looking at the toe it could be straight, but what you need to look at is the total camber and caster (example if you have to much pos. camber on the left wheel than the right wheel it will push to the left, and if you have a high caster on the right side it will push to the left) hope this helps
