bronco pulling
1970mule
when i brake the bronco pulls to the right. This happens only sometimes and it pulls harder sometimes and slightly others. any ideas?
Rockin69er
Do you have drums still on the front? How fresh are the shoes,wheel cylinders etc? If everything is fairly new the right might be adjusted to tight or the left not enough.
broncnaz
Ah the famous drum brake steering. either you need to readjust the brakes or a wheel cylinder is leaking and causing less braking action. Some other less common causes is a loose or tight wheel bearing.
SHX669
It could be front or rear .
You might try backing up and braking hard . That's how the self adjusting brakes adjust .
If that doesn't work ; use a brake adjusting tool or screwdriver to adjust the one that's loose. The adjuster " nut " should be accessible through the slot on the backside of the backing plate.
Stan
Pedestrian
Bronco Missionary
Check Shoes, my PO had installed the leading shoe backwards on the right side.
Explorer
Raphine, Virginia
One more to add to the list is a brake hose may be going bad. When they get old and soft they will collapse and hold residual pressure. Next time braking , brake is partially on to start with. When really bad, one wheel will lock and not release at all.
