Green76
I just tried installing a set of black Scott Drake bronco script valve covers, permaseal gaskets, breather and hardware that I got from Wild Horses and I'm having interference problems. I got a new set of Edelbrock RPM heads and comp cams 1.6 roller rockers (part number for chevy). My friend that has been an engine builder for 40 plus years says that the rockers will work for a 302. The problem I'm having is that the oil deflector that is attached to the inside of the valve cover, under the breather, is hitting on the pivot of the rocker panel (side pivot). I installed this valve cover with the 1 1/4 inch breather on the passenger side head (the one with interference problems). I installed the pvc valve cover on the drivers side head. I unbolted the deflector from the passenger head and bent the deflector but I'm leary of the rocker rubbing on the deflector. If I were to remove the 2 bolts that hold the deflector in the head, and completely remove it, what can I install in the 1 1/4 inch diameter riser on the valve cover to deflect the oil prior to it getting to the air filter? Does it matter which valve cover gets installed on which head? ![Stick out tongue :p :p](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
