Bronco stalling on highway and won’t restart.
rbwamsley
Looking for some help on where to start with my issue, as it has left me stranded on the highway three times. Two times, my bronco has died while driving at 60mph (90 degrees plus outside). The other was pulling into park (70ish degrees out). After that, the truck will not start for a long while (20-40min).
I’m not sure where to start looking or what could cause it. Any help would be appreciated.
302 with a Petronix HEI correction: DUI HEI
gnpenning
Bronco Slave
First thing to check for is spark. Start at the spark plug and work your way back. Carry a old spark plug and a multi meter. Generally electrical if it fails hot but works after cooling down. Check and test.
Do not throw parts at it
Since you said it just quit, I don't it's fuel related but it's a quick easy check looking down it to the carb and operating the throttle. Look for a squirt of fuel.
73azbronco
how old are all the electrical ignition parts, coil, wires plugs, ignition relay, anything in the dizzy?
Possible vapor lock, what is fuel pressure? I'm not betting on it though.
R
rbwamsley
Plugs and wires are roughly 7yrs old. Everything else is unknown, but over 10 years.
Just to be clear here, when you say it won’t start, does the starter still crank the engine and it just doesn’t fire up? Or does it not even crank when you turn the key?
If it turns out to be a no-spark condition, carry some water with you and when it happens, pour water over the coil and let it cool down for a couple of minutes to see if that helps.
But even before it happens again, you should be checking for reliable voltage at different places. Is it sitting dead now? Or will it fire up like normal?
What year is your bronco?
What ignition does it have? I see you said Pertronix, so does that make it a 73 or older bronco? Or did you change out Dura Spark for Pertronix?
Is it original Wiring?
Seven years is a long time for some components, but a bad plug wire or two won’t kill the engine going 60 miles an hour. Doesn’t help things, of course! But they wouldn’t be working by themselves. It can certainly make the coil work harder and hotter though.
And Pertronix Ignitors work very well, but can also fail as well. Just like anything else.
If there are any splices in the electrical wires to the ignition components, I would closely inspect them, or maybe even replace them.
Any water getting down into a butt splice and causing corrosion, can cause this intermittent dying and no start.
Had that happen myself. Positive wire to the coil head corroded about 6 inches away in the harness.
R
rbwamsley
It does not fire up. Cranks just fine though.
It's an HEI setup, so just pour the water over the dizzy? Correction from above I have a DUI HEI. What places should I be looking for reliable voltage?
It will start now.
'74
Correction from my original post. I have a D.U.I. HEI not a Petronix. Sorry about that. Yes, original wiring.
Good to know. Big difference! :)
First thing I would do would be to grab an extra high-quality ignition module. Not the cheapest thing you can find just because it has a lifetime warranty, but probably the most expensive one you can find.
Maybe even one from Pertronix or DUI.
Second, or maybe even first instead, verify where power is coming from for the distributor.
If your left side (ignition, or “I” maybe?) wire on the distributor, cap is going to the stock red with green stripe wire, that could be the source of your problem.
The HEI setup is meant to run on a full 12V and not the lower voltage coming through that wire.
Different ways of achieving this, but probably best and easiest is to use a relay.
Without a relay, the HEI could put more strain on that particular wire from the ignition switch. This could be the cause of your intermittent working as the wire heats up naturally, but heats up even more due to the higher demand of the HEI.
I don’t know what the current ratings are for HEI versus standard ignition, but I have heard that it’s more.
So, a few more details, please.
But to answer your previous question, yes, as long as you don’t go crazy, pour water over the top of the distributor.
Obviously, you don’t want water getting inside, but anything that can more quickly cool the coil area would help narrow down a solution.
hsach
Members Only
Definitely check spark, but also check your fuel pump. Not sure if you have electric or manual. These symptoms also point to a weak/dying fuel pump. I just changed one on my '78 bronco last weekend, 3rd or 4th in recent years. I switched from a Carter to a Delphi to see if that lasts longer. A dead pump is easy to diagnose, a weak one is a pain in the ass, especially in the summer heat and elevation, if that affects you. I use ethanol free gas only now, have all new fuel lines from tank to carb, new tank and sending unit, and I still see modern mechanical fuel pumps fail. Reading DirtDonks reply above, I would do all of what he is suggesting, but I would also change out the fuel pump if you can. Very easy job if it is a mechanical setup. Good luck!
R
rbwamsley
I still have a manual fuel pump. I replaced it roughly a year ago.
Believe it or not, that’s actually bad news.
Bad, because new pumps tend to be crappier than old pumps.
Bad too, because we tend to drive our Broncos a lot less than we used to. And an almost guaranteed early death of a fuel pump is to not drive very often.
Are you able to drive your bronco often, maybe even as a daily driver? Or does it have to sit for weeks at a time?
nvrstuk
Everybody has great Q's and troubleshooting tips...
Just need some more answers! :)
OP, let us know if you get it going!
