About a month ago, I was firing up my newly rebuilt bronco (by me) and getting ready to go for a spin. It had been running fine since November 2020. I was putting miles on it to break it in for the first oil change and just driving around enjoying it. I had driven it ~ 500 miles total with no issues. It needed a tune up but was running fine at my home elevation of 7500ft and down in town at 5000 ft
It fired up fine, idled for a while........then died. Then I couldn't start it.
Nothing changed, nadda....I hadn't changed a thing from when I parked it a week earlier.
Now it will fire up.......run for around 15-30 seconds then die and it won't restart.
Engine is a mild 351W build...
With the suddenness of the failure, it only makes sense that it is an electrical/ignition issue. It has a points/condenser/stock distributor, flamethrower coil.
I replaced the ballast resistor and voltage regulator because I though they might have failed suddenly.
I've played with the timing and screwed it up even more.
I pulled the plugs to see if I was fouling plugs.......nothing, clean as a button.
When it does run for those brief 30 seconds......it runs great......no knocks, no ticks, good oil pressure.
I am flabbergasted and just plain frustrated.
Please help.
Thanks,
Chris
Please help.
Thanks,
Chris
