Probably so cause it was built 7-16-76 and have seen a '77 that it's actual build date was very late July '76.
77 model
Jan. 77 is X 8xxxx - X 9xxxx
Feb. 77 is Y 0xxxx - Y 1xxxx
Mar. 77 is Y 2xxxx - Y 3xxxx
Apr. 77 is Y4xxxx - Y5xxxx
May 77 is Y6xxxx - Y7xxxx
Jun. 77 is Y8xxxx - Y9xxxx
Jul ..77 is Z0xxxx - Z1xxxx
Aug 77 is Z2xxxx - Z9xxxx
With all due respect...
Sure enough, cancel the screenshot idea!! I'm not sure where that falls if you're not claiming as your own or selling it though.
It would be nice if we could all contribute to fixing the errors on that page. I tried many years ago and was ignored.
Personal use?
You are probably okay (even if you did get caught).
Publishing it or posting it on the net?
That could get expensive.
Over the years I have read that there are many errors on their site.
Since this is the largest EB forum maybe we need to have the most knowledgeable on here make a more correct set of tables in the FAQ section.
I've contacted them as well with no reply.
Like in this thread lol
2x
There's a bunch of errors. I'd be all for making a VIN section of the forum here. Everything is out there already and just needs to be compiled like the "color code" thread, except for the trim codes and special order codes. Pretty sure between viperwolf1 and myself we have all of the trim codes.
We should have our own decoder on this site. With all the knowledge on here between a certain few members we coukd do it and not have to worry with broncohio.
Should be a sticky even! How would you start?
I was told to get a education for all , up to 1972 from .....
http://www.fordification.com/tech/VIN67.htm
