70EB
today, i pulled the interior to inspect the floor pans. im gonna have to do a little work on them. also bought a complete 1990 5.0 engine with serpentine pulleys. ill need to find out if my c4 torque convertor will work on this late model engine and if the mustang stock headers will work and how the distributor and alternator will wire up and if the serpentine set up will fit in between the radiator.what about the flywheel ? any advice ? thanks.
C4 T/C should bolt up. Ensure you use the 5.0 flexplate and not the older 302 flexplate. The balance on later 5.0 is different.
Stock headers will fit but the outlet on the pass side will be very close to the framerail (it will turn down right into it). Should be enough room to be creative with exhaust.
Serp setup will fit with the radiator. I did this on mine when i swapped Mustang serp on the 351W. I have a aftermarket aluminum rad that is thicker than stock and had to move it foward a little. With a stock radiator, you will get even more room since it is thinner.
For the radiator hoses, run the crossover tube for the lower and the GTO (68 GTO w/400) upper.
