- Joined
- Mar 10, 2010
- Messages
- 652
My 76 that I picked up a few months ago had a shift problem. If you took off from a dead stop slowly it would shift into 3rd very quickly. If you got on it taking off it shift normal. I adjusted the screw in the modulator by turning it clock wise a little at a time until I had it 2 turns in but it did not help. When I got back from Super Celebration the cooler for the transmission in the radiator started leaking. Transmission fluid in the coolant and coolant in the transmission. Flushed the engine and transmission several times. The last time I had the transmission pan off I decided to change the modulator. Replaced a green stripe with another green stripe. After installing the new modulator with the pan off I noticed the pin was not tight against the throttle valve. I can move it back and forth a little bit. Should I go ahead and adjust the modulator until the pin fits tight or wait until I have it running and driving before adjusting. Thanks in advance for the help
James
James
