NC-Fordguy
Greetings all
I Recentley purchased a 1974 bronco and have been going through it prioriatizing the things that need to be fixed.
When cold the transmission will not shift into 1st, 2nd or drive. After it warms up it will shift into gear fine. When cold it has no problems going into reverse. When it is warmed up everything works fine, no problems, no slipping that I can tell. The previous owner changed the fluid and it looks good. I'm thinking there is a peice of trash stuck in one of the valves. You all think one of those power flushes will solve the problem? Any suggestions??
Ed
Ed
