keithb
Ok, I am finally getting this truck together. My C-4 has two vacuum hoses that go to the modulator valve. My 73 pickup C-6 only has one. That one was easy, but where do the two lines go on the bronco? I figure one goes to manifold vacuum while the other must go to the carb for ported vacuum. But I don't know which is which or if this is even correct. Anyone know this stuff? I have the rear most port on the valve going to manifold vacuum. Where do I run the other one and is that the correct order?
