My '74 had the double vacuum fitting modulator on it when I bought it and I don't think it had the screw in the port for adjusting (I'm not 100% sure though) but when I rebuilt everything, I replaced it with the green striped adjustable style modulator valve.
I had to modify the mounting bracket some or you can purchase the correct bracket for the single port / adjustable type - the brackets mount to the transfer case bolt in the same location but the bracket itself was a little bit different for the double versus single vacuum port modulator.
If you happen to have the screw in style modulator as opposed to push in / bracket style, I would imagine they offer an adjustable version but I'm not sure
If you install an adjustable modulator, it might come with a new pin as mentioned above but regardless you will have the benefit of being able to adjust the shift points to your liking.
If you decide to install the adjustable type, the adjustment is pretty sensitive, 1/4 to 1/2 turn adjustments at a time result in noticeable differences but you may have to make a few attempts to dial it in.
DJs74
