c bushing install
zenadog
St. Louis mo.
Getting ready to put my c bushings in. I was looking at the radius arm clamp that squeezes the bushings and noticed the inside of the clamp is a little thicker on one side than the other on each clamp. does it matter how that goes back together? Hopefully I described it right.
nathan.hall1
Central Washington
Make sure you read up on the Bronco Lean the first time I did it, I didn't have the axle level when I tightened it all up I sat almost 2 inches higher on my passenger side. Wild horses has a great write up on the subject..
Z
zenadog
St. Louis mo.
thanks guys, but let me try explaining a different way. The castings on the inside part of the c caps that clamp around the bushings are thicker on one side than the other on each clamp . does it matter if those go in with the thicker part towards the outside or towards the inside of the vehicle.
dave67fd
Maybe we are missing your description but again they only go on one way. The arrows point at the bolt holes. These mount "up" and are where your spring cups mount to.
Each cap can be on the either side of the arms although I believe they were originally machined as one pair so they should be matched up with the side they originally started with if you can but they will still work fine either way.
If you have one side thicker than the other it is probably built up slag and should be removed and cleaned up. see my cap after all the slag was removed.
frenchy
I remember learning this all on my own by trial and error, way before the internet I was the only Ford guy in the club. I'm glad for all the info out there now good luck and take your time it's all easy to learn. Have Fun Go Broncco'n
frenchy
That's some nasty looking stuff Dave!
What did you use to clean/chip it off? Chisel, screwdriver, just a brush? Any chemical enhancements, or just dry?
dave67fd
Hey Paul,
I started off with the air chissel and then put her in a vise and used a sharp screwdriver and hammer then just cleaned up with the die grinder then sand blasted them. That first pic in the last post isin't mine, I just used it for clarificarion. If much more slag came off them I probably would go with another set. Here's what they look like after blasting and primmer.
Regards
If that's 2° "positive" (as opposed to negative) and you only have 31" tires or smaller, that might be enough to get you by. But "optimum" is a word we haven't quite settled on yet!
In general though, if you have power steering you can get away with more, so at least 4 degrees positive is a good start, with 4 to 8 being a good overall range. If you can get it somewhere in the 5 to 6 degree range you're in the money.
Hard to do on most EB's prior to '76, and even harder to do while keeping your front pinion angle acceptable.
What year do you have?
What are the other specs?
What else has been done to the rig? Do you know if it's got replacement C-bushings or any other corrective measures done already?
