jeremywatco
Finally getting the front end put back in. First things first.. c-bushings. I have the 4 degree off-set bushings from WH that came with my 4" lift from WH.
I lubed everything up with soapy water and went for it... using a crisscross pattern to tighten the clamps.
What I did it had the front axle sitting in such a way on jack stands that both arm tips touched the ground.. and then I went for it.
No matter which way I do it one of the arms tips will settle in at around 1/4" off the ground while the other touches... I'll loosen up again.. and re-tigthen.. always same result. Trying to avoid any lean. Is there an acceptable amount of error with these bushings? I would hate to get it all together and have it leaning. I also have adjustable track bar to pull it into center once I get this all done.
Thoughts?
Thoughts?
