c bushings which ones
wesleydax
Hi, thanks to everyone for a great place to find out stuff. been lurking for a while. a little back ground on my bronco. its 71, 302 changed to automatic, 4 wheel disc with hydro boost (should have done that 20 years ago). 3.5 superlift, just upgraded to 4 turn box. thinking i need c bushings. the steering has no loose joints but its touchy. was searching previous post and camber could play a part in that? my current bushings cam with the lift kit but that was 18 or so years ago. would a new set of 7 degree bushings be in order? thanks for the help
Hey wesleydax, welcome out of the lurker state, finally!
Good question. My automatic answer is to use the 7° bushings no matter what lift you have. It's "caster" that you're thinking of though. Camber is when the tops of the tires are tilted inward (negative camber) or outward (positive) compared to the bottoms.
Caster is when the top ball-joint is tilted to the rear of (positive caster) or in front of (negative caster) the lower ball-joint. In a nutshell anyway.
Your '71 probably did not have sufficient positive caster from the factory anyway (most did not until later years), so the largest bushings you can use would be your best bet.
However, the only way to know for sure is to take it to an alignment shop and have them check what the current settings are. If they can give you a printout of your readings, so much the better. What you want to achieve is AT LEAST 2° positive caster. When I say "at least" that means that 3 to 4 would be better. Some of the members here with good power steering systems and larger tires are running 6 or more degrees.
Anyway, long story even longer, use the 7's.
Oh, and have you checked the entire front end using the test with a helper turning the steering wheel back and forth? With the weight of the truck on the ground, that puts a lot of torque into the components and lets you see a whole lot of motion that you can't see normally. Even if you're right about the steering links being tight, you might see that your trackbar bushings/bolts are allowing movement side to side, which will give you that twitchy/loose/wandering feeling too.
Good way to make a cracked frame behind the box show up too!
wesleydax
wesleydax
ok 7s it is. thanks for the info. yes i checked everything to make sure i didnt have any loose motion. i replaced the trackbar bushings and tierods and stuff last summer. checked the frame good when i swaped the box. im going to townsend this weekend so maybe there will be some bushings there.
.94 OR
Willamette Valley, OR
I have a Skyjacker lift of similar vintage to yours. I recently installed 7° bushings to clear up the "wander". That and stabilizing the track bar mounts did wonders. When I originally did the lift, the thing still wandered real bad and I tracked that down to the bushings in the rear springs being worn out and the rear end would change directions with the changing grooves in the pavement. Now, it drives pretty fair.
Yeah, one time I did all the new stuff, but still had a wander too. Even after the new rear spring bushings went in, it only got a little better. Finally found (through the test) that the lower trackbar mount itself was loose. A couple of new tack welds later and it was like a new truck!
And regarding what I said about many, if not most, earlier model Broncos not having sufficient caster to begin with wesleydax, mine has 3.5" of lift with 7° bushings and is still at only 1 and 1.3 degrees positive. Below recommended specs even with all that bushing offset in there.
So maybe, even after you install the bushings, when you get the chance to, put it on an alignment rack to see what you've got. That knowledge can steer you in the right direction in the future if you need any further adjustments.
wesleydax
wesleydax
I have not thought of rear spring bushings at all. but yea i got that going on as well. going to get new bushings for rear. and new c bushings. Im going to the show or whatever it is in townsend friday will there be any vendors there? its a shame im only 2hrs away and never been. always been on other side of the mountain at grand run. thanks guys, i really appreciate all this info.
Enjoy the show. Hope you meet some other EB owners while there. Not familar with it myself, so don't know if any vendors will be there.
Although we like to support our Bronco vendors, in a pinch, you can sometimes get the C-bushings from standard (but well stocked) auto part stores. Or if you have a 4-Wheel Parts store nearby, they'd have ready access to them, even if they don't always keep them in stock anymore.
have fun
.94 OR
Will the axle take a set in the bushings to the point that if you are having caster issues, you could put a positive twist in the axle as the end caps are tightened up? Ideally, I can see having the frame rails at a set height from the floor and the axle also at a uniform height, then push the pinion down a bit (come up with your own means to do this) then tighten the end caps on. Or will the axle end up floating back to the molded "center" where the axle wants to ride?
It's pretty much going to re-center always. And if it does distort and stay at some point, I'm pretty sure that the difference is absolutely minimal.
When it comes right down to it, in many of the severe cases where the owner was just not satisfied, the only real solution was to set the pinion angle with the bushings (less is better in this case) and then cut the outer steering yokes off the axle tubes and rotate them to correct the caster to whatever you want. Re-weld them on and off you go. The best of both worlds.
Most don't need to go to that much trouble, but a lot do and it's well worth the extra effort.
There are even a few here who've found shops to do it for them for what I consider a very good price. Couple hundred bucks or so, and they're done.
