My C4 is not shifting into low when I stop. It also rev's when it tries to go to drive from second. Reverse works fine. Now I can't even get drive unless I rev it to high rpm's going downhill. Everything I googled said to check the governor. Dropped the Transfer case and removed it. It was a little dirty but both valves moved freely. I pulled the valves and compared them to another one I had on a spare C4 and this is what I found. (pic below) The one on the right is the one that was in there.
It's been running fine for the 50 miles I've been driving it until now. I bought it used and was told that it was rebuilt and had a shift kit installed. Any thoughts?
Oh, and I switched the Valve Body with the spare trans and still had the same symptoms.
